[mapguide-users] Cannot Create Layers From Feature Sources
gom
gord.mckenzie at canam.com
Thu Sep 27 08:25:29 PDT 2012
Further to my difficultiess with unmanged data sources in 2.4, I wonder if
the following images help. As you can see the schema name is different in
the two previews of the same data source. If I do this comparison on the
same datasource under 2.2 the names match. This suggests to me an issue or
possible answer as to why I cannot create layers from these datasources? I
have no idea why the difference exists but it happens to anything I import
from a package or anything new I create. *Schema Name of data source as
shown in Maestro using the Preview function on the Toolbar. This is the
<http://osgeo-org.1560.n6.nabble.com/file/n5004985/schema1.png> *Schema
Name of data source as shown in Maestro using the Local Preview function*
schema2.png <http://osgeo-org.1560.n6.nabble.com/file/n5004985/schema2.png>
gom wrote
> I have a number of unmanaged SDF files in a folder. (2 point sdf files,
> 3polyline (curve) sdf files) I have them authored/working nicely on an
> activeMapguide 2.2 server 32 bit version on IIS. I exported them as a
> package andimported them to my development workstation. Windows 7
> Professional,Mapguide 2.4 RC1. I have another test server Windows 2008
> IIS with 2.4 RC264 bit where I did the same.The data files are available
> for authoring in the Mapguide Studio/Maestroprograms. I can create data
> sources and use the preview functions on theprograms to view the schema,
> attributes etc with no trouble. I see a validgeometry property. In
> addition I can preview the features and see theobjects drawn as expected.
> Permissions seem to be consistent across thethree machines.All the layers
> for 4 data sources are broken. When I go to modify a layer,and select one
> of the 4 data sources, I get an errors. When I try to createa new layer I
> get the same errors. Re-creating the data sources makes nodifference.
> (One of the polyline data sources is still working asexpected). I edited
> and saved each file in AutoCAD map to ensure I couldread/write them
> successfully.In Maestro 4.0.2 it says "Feature Source (xxx) has no usable
> featureclasses. Choose a different feature source.", then it says "The
> Resource IDcould not be found."In Mapguide Studio 2010 and 2011 it says
> "Object reference not set to aninstance of an object." The layer dialog
> shows the selected FeatureSourcename and the expected schema in the
> dropdown list but Geometry drop down hasno options.I have tried every
> variation of new feature sources and layers but no luck.Is there something
> I am missing? Can anyone suggest some different tests orapproaches I can
> take to sorting this out?mapguide-users mailing list
> mapguide-users at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/Cannot-Create-Layers-From-Feature-Sources-tp5003380p5004985.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120927/e851da8a/attachment.html>
