[mapguide-users] MG 2.5 with MSSQL, compound SQL in filter fails.
Ward Kilby
wkilby at telus.net
Tue Apr 2 17:15:47 PDT 2013
With MSSQL using a compound SQL statement in the layer filter ( OR, AND)
causes selection to fail in MG 2.5 and 2.4. But worked fine in MG 2.2. The
correct data will plot on the map but the tooltip data and selection data
will default to a single feature for all data displayed. If no or a simple
SQL statement is used all is good. In some cases it is an easy workaround
using '%' but there are other cases where a compound query would be very
useful. Suspect it is a FDO issue like the geometry-geography problem.
View this message in context: http://osgeo-org.1560.n6.nabble.com/MG-2-5-with-MSSQL-compound-SQL-in-filter-fails-tp5044156.html
