[mapguide-users] 64-bit woes
Hans Milling hm at geograf.dk
Fri Apr 12 00:06:36 PDT 2013
Oh, and by BTW, I created a small command line tool to check all .exe and
.dll files in a folder. The tool will display if binary files are x86, x64
or Any (in case they are .net). Also version numbers are displayed.
Just copy the tool to the location of your binary files and double click it.
All binaries should be either "x64" or "any" if you are running 64 bit.
(Create an empty console project and paste the following code):
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5046294.html
