[mapguide-users] How to save Layer in physical position.
Zac Spitzer
zac.spitzer at gmail.com
Wed Apr 24 00:00:42 PDT 2013
I think this might need a different solution...
In oracle you can set the default extents via the sdo_meta_data tables
which then is used as the default extents for a layer in MapGuide ...
maybe that works for tab files, but it would be limited to one position per
file
but, much simpler, there is a Link to widget for Fusion which allows you to
bookmark a specific map view
On Wed, Apr 24, 2013 at 4:57 PM, Rahul Gupta
<rahul.guptamcakiet at gmail.com>wrote:
> Thank you Jackie for reply. can we do this thing through coding(.Net).
> Rahul Gupta
> http://osgeo-org.1560.x6.nabble.com/How-to-save-Layer-in-physical-position-tp5049266p5049281.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130424/391d8ebf/attachment.html>
