[mapguide-users] I am having trouble installing Mapguide Open Source 2.5.0 in a Hostgator VPS running CentOS 5
FX2000 fx2000 at gmail.com
Thu Apr 25 08:41:48 PDT 2013
I am running the CentOS install script (
http://download.osgeo.org/mapguide/releases/2.5.0/Release/mginstallcentos.sh
<http://download.osgeo.org/mapguide/releases/2.5.0/Release/mginstallcentos.sh>
) and everything downloads fine, but when it gets to the part where the
script runs the chcon command I get a bunch of these:
chcon: can't apply partial context to unlabeled file ***FILENAME***
Afterwards I get these error messages:
/usr/local/mapguideopensource-2.5.0/webserverextensions/apache2/bin/httpd:
/lib/libc.so.6: version `GLIBC_2.10' not found (required by
/usr/local/mapguideopensource-2.5.0/webserverextensions/apache2/lib/libapr-1.so.0)
/lib/libc.so.6: version `GLIBC_2.9' not found (required by
/usr/local/mapguideopensource-2.5.0/server/bin
./mgserver: error while loading shared libraries: libcurl.so.4: cannot open
shared object file: No such file or directory
And this is what happens when I try to run mgserver.sh afterwards:
I am hosting the entire log of the install process here in case it helps:
https://dl.dropboxusercontent.com/u/8322905/mginstall.txt
<https://dl.dropboxusercontent.com/u/8322905/mginstall.txt>
Thank you for your help.
Daniel
View this message in context: http://osgeo-org.1560.x6.nabble.com/I-am-having-trouble-installing-Mapguide-Open-Source-2-5-0-in-a-Hostgator-VPS-running-CentOS-5-tp5049667.html
