[mapguide-users] 64-bit woes
Hans Milling hm at geograf.dk
Sun Apr 28 23:55:32 PDT 2013
According to M$ the error code 4 means: Initialization error occurred. There
is not enough memory or disk space, or you entered an invalid drive name or
invalid syntax on the command line.
My best guess is that the compiler (like visual studio) is 32 bit and when
trying to copy from "Program Files" it actually copies from "Program Files
(x86)" where MapGuide is not installed. You can try to edit the bat/pre/post
build (or where the xcopy commands are located) and add:
echo Program files x86: %ProgramFiles(x86)%
If the output is blank, the xcopy is running as 32 bit else you will see an
output similar to:
Program files: C:\Program Files (x86)
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/64-bit-woes-tp4182647p5050129.html
