[mapguide-users] Acres in the Fusion Measure Tools?
JamesDudden
jamesdudden at blueyonder.co.uk
Fri Aug 2 01:34:15 PDT 2013
Thanks for the reply Gordon. I followed exactly what you did above i.e. added
the code to the measure.php and the measure.js both in the places you
describe but nothing happens. I can see a new line in the task pane for
'Total Area' but it never gets populated with anything.
Is there anything else that needs to be added/tweaked? I don't understand
why this doesn't work.
For testing purposes I tried amending line 585 of measure.js
tArea.innerHTML = value + ' ' + units + '<sup>2</sup>'
to this
tArea.innerHTML = value + 'TEST'
but again nothing changed in the taskpane. I tried restarting Mapguide but
still no joy. It's almost as if the measure.js file I'm amending isn't the
one being used - could this be true or is there something else I'm missing?
Thanks
Software-Matters
View this message in context: http://osgeo-org.1560.x6.nabble.com/Acres-in-the-Fusion-Measure-Tools-tp4481821p5070413.html
