[mapguide-users] Map Menu, i can't pan after select an another map
renardchan emailvalide at yahoo.fr
Fri Aug 2 04:15:20 PDT 2013
I 'm using mapguide os 2.4 + maestro 5.0. I would like use several map on my
application definition (fusion - slate). But i have a problem : when i
change my map, i can't pan the map.
Moreover i check override Initial View, but my map isn't center where i
want. I tested this with single tile.
Thanks by advance
Regards.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Map-Menu-i-can-t-pan-after-select-an-another-map-tp5070445.html
