[mapguide-users] Error on insert features into SQL Server Spatial
David Hequet
david.hequet at free.fr
Wed Aug 7 07:55:18 PDT 2013
I'm getting this error with infrastructure map server 2013, it use FDO 3.7
but i don't know if it use the patched version of Mapguide's core. Does
someone know?
I have tested this on both fdo enabled/not enabled database. Tried with Id
columns as identity and as simple columns (providing id during the insert
command).
Same effect: data is inserted but got this error as response.
thank you,
David
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-on-insert-features-into-SQL-Server-Spatial-tp4987600p5071317.html
