[mapguide-users] mapguide 2.4 sql server spatial feature source - can't select the data store and can't use join extensions
David Hequet
david.hequet at free.fr
Thu Aug 8 06:56:28 PDT 2013
Did you solved this one?
The server principal «myUser» is not able to access the database
«OneOfTheDatabasesInTheServer” under the current security context
I think it is security related problem but i'm not familiar with sql server.
David
View this message in context: http://osgeo-org.1560.x6.nabble.com/mapguide-2-4-sql-server-spatial-feature-source-can-t-select-the-data-store-and-can-t-use-join-extenss-tp5033688p5071511.html
