[mapguide-users] Showing images on map
Jackie Ng
jumpinjackie at gmail.com
Tue Aug 13 03:02:59 PDT 2013
Completely off the top of my head without any idea if it will actually work:
Make a temp feature source. Insert a point into it (representing the
position on the map where you want the image to appear, centroid of the
tooltipped feature would probably suffice).
Make a temporary image-based Symbol Definition, embed the associated image
into this Symbol Definition. There's a whole boatload of various
symbolization settings to play around with here.
Make a temporary Layer Definition off of the temp feature source using
Composite Symbolization and reference the Symbol Definition you've created.
Make a new MgLayer off of that Layer Definition, insert into your map. Feed
that map to the Rendering Service.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Showing-images-on-map-tp5072235p5072245.html
