[mapguide-users] I can't modify the en.json file
renardchan
emailvalide at yahoo.fr
Thu Aug 22 08:12:14 PDT 2013
Thanks for your advices. I find it. Text are read in fusionSD-compressed.js.
(You can check it in fusion.js at line 98585.
Fusion.Strings.en = {
'scriptFailed': 'failed to load script: ${script}',
'configParseError': 'Error parsing fusion configuration file, initialization
aborted',
'configLoadError': 'Error loading fusion configuration file, initialization
aborted.' +
'Make sure that you have copied config_dist.json to
config.json ' +
'and have configured the settings for your system',
'ajaxError': 'Exception occurred in AJAX callback.\nMessage:
${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
'importFailed': 'failed to import stylesheet: ${url}',
'serverNotAvailable': '
Server not available. Try to reload the application. If this problem
persists, please contact the administrator
'invalidXMLDocument': 'xml2json: invalid XML document: ${msg} : ${url}',
'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
'appDefLoadFailed': 'failed to load: ${script}',
'appDefParseError': 'failed to parse ApplicationDefinition',
'widgetSetParseError': 'failed to parse the WidgetSet',
'fusionError': 'Fusion Error: ${type}\n${message}',
'nullExtents': 'Map.setExtents called with null extents',
'mapLoadError': 'Failed to load requested map:\n${error}',
'setLayersError': "setLayers failure: ${error}",
'printTitle': 'Printable Page ',
'noSelection': 'No features selected',
'selectionInfo': '${features} feature(s) selected on ${layers} layer(s)',
'attribute': 'Attribute',
'value': 'Value',
'taskHome': 'return to the task pane home',
'prevTask': 'go to previous task executed',
'nextTask': 'go to next task executed',
'taskList': 'Task List',
'taskPane': 'Task Pane',
'imperial': 'Imperial',
'metric': 'Metric',
'deg': 'Degrees',
'refresh': 'Refresh',
'expandAll': 'Expand All',
'expand': 'Expand',
'expandTheme': 'Expand Theme',
'otherThemeItems': '... (${count} other styles)',
'expandCompressedThemeConfirmation': 'Expand this theme?',
'collapseAll': 'Collapse All',
'collapse': 'Collapse',
'defaultMapTitle': 'Map',
'legendTitle': 'Legend',
'selectionPanelTitle': 'Selection',
'ovmapTitle': 'Overview Map',
'ovmapTitleShort': 'Overview',
'taskPaneTitle': 'Tasks',
'segment': 'Segment ${seg}',
'calculating': 'calculating ...',
'panWest': 'Pan West',
'panEast': 'Pan East',
'panSouth': 'Pan South',
'panNorth': 'Pan North',
'zoomOut': 'Zoom Out',
'zoomIn': 'Zoom In',
'printCancel': 'Cancel',
'printGenerate': 'Generate',
'zoomRect': 'Zoom Rectangle',
'maptipLinkText': 'Click for more information',
'redlineLayerName': 'Digitizing Layer ',
'printShowTitle':'Show Title?',
'printOptions' :'Options',
'printTitleText':'Title',
'printShowLegend':'Show Legend?',
'printShowNorthArrow':'Show North Arrow?',
'quickPlotResolutionWarning':'The current settings exceed the map
resolution. Zooming out or increasing the scaling will help create a more
legible plot',
'noCommercialMapLayers':'NONE',
'googleStreet':'Google Street',
'googleSatellite':'Google Satellite',
'googleTerrain':'Google Terrain',
'googleHybrid':'Google Hybrid',
'yahooStreet':'Yahoo Street',
'yahooSatellite':'Yahoo Satellite',
'yahooHybrid':'Yahoo Hybrid',
'bingStreet':'Bing Street',
'bingSatellite':'Bing Satellite',
'bingHybrid':'Bing Hybrid',
'openStreetMap':'Open Street Map',
'openStreetMapTransportMap':'Open Street Map (TransportMap)',
'openStreetMapCycleMap':'Open Street Map (CycleMap)',
'end': '',
'measureInProgress':'Measurement is currently in progress',
'selectPolygonPrompt':'Click to add a vertex to the selection polygon.
Double click to complete the polygon and select all features with it',
'selectRadiusPrompt':'Click and drag to the desired radius to select'
View this message in context: http://osgeo-org.1560.x6.nabble.com/I-can-t-modify-the-en-json-file-tp5073605p5073840.html
