[mapguide-users] Maestro API 5 - GetLegendImage fails
Hans Milling
hm at geograf.dk
Mon Aug 26 05:47:09 PDT 2013
I just checked with a test map with no finite display scales, and where all
layers are 0 to infinity. But still the same error. A scale of 5000 should
fall within a valid range in any case now.
Can i get some verbose/debug output from the mapguide server to get a hint
of what is failing?
will set cpl_debug=on be enough or do you have some better trick?
Hans...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Maestro-API-5-GetLegendImage-fails-tp5074008p5074316.html
