[mapguide-users] MapGuide Maestro Error.
    Jackie Ng
    jumpinjackie at gmail.com
    Thu Aug 29 23:23:43 PDT 2013
If you edit something from the Editor UI, and then you click "Edit as XML" on
that open editor and *do not see any changes* that you're expecting in the
XML you're looking at, then it's some defect in that particular editor.
If this is the case. Please file a ticket and outline the steps you've taken
to produce the problem
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/MapGuide-Maestro-Error-tp5074519p5075138.html
