[mapguide-users] Passing more than one parameter on Task Pane InitialTask
marcebil marcebil at gmail.com
Sat Aug 31 07:40:59 PDT 2013
In Maestro, 5.0
Calling a php with a widget, in this case the TaskPane, through the
"InitialTask" attribute,
if i call a php with just one paremeter, as in:
htttp://localhost/mapguide/something.php?par1=10
it works fine, and i receive the value in the php.
But if I want to add a second parameter, as in:
htttp://localhost/mapguide/something.php?par1=10&par2=20
It gives an error when trying to save the widget, not letting to save it.
The question is:
Can i add a second parameter, and if the answer is yes, how it must be done?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Passing-more-than-one-parameter-on-Task-Pane-InitialTask-tp5075401.html
