[mapguide-users] GDAL Fix for MapGuide OpenSource 2.5
Berg, James James.Berg at stantec.com
Fri Dec 6 06:34:13 PST 2013
I'm pretty sure MGOS 2.5 still uses GDAL version 1.9 so this old posting for installing ECW support on MGOS 2.4 should still be relevant. The posting should contain the url for the correct dlls.
http://osgeo-org.1560.x6.nabble.com/Step-by-Step-for-ECW-and-MGOS-2-4-td4995445.html#a4995528
Back when I installed MR Sid and ECW support on MGOS 2.4 I used the url you posted to figure out which files go where, but I can't guarantee that will apply to 2.5.2
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Hans Milling
Sent: Friday, December 06, 2013 7:03 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] GDAL Fix for MapGuide OpenSource 2.5
Hi All
Is there a GDAL fix for MGOS 2.5? Similar to this:
http://trac.osgeo.org/mapguide/wiki/MGOS22GdalProvider
I cannot get ECW files to work in MGOS 2.5.1 so My guess is that I need to
apply the same fix to apply the missing files.
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/GDAL-Fix-for-MapGuide-OpenSource-2-5-tp5093099.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
