[mapguide-users] local connection
mika at digikartta.net mika at digikartta.net
Mon Dec 9 01:57:04 PST 2013
I just can't get over of these problems.
Maestro 5 + local native connection + AIMS 2014
First I had problems with ResourceExists and now with
SetResourceXmlData (resource service). My application crashes with
either error:
<2013-12-09T11:40:10> 	4136			Administrator
  Error: Failed to retrieve message for "MgFeatureServiceException".
         An exception occurred in FDO component.
         The identifier 'ID' was not recognized.  (Cause: , Root Cause:
The identifier 'ID' was not recognized. )
  StackTrace:
   - MgFeatureServiceHandler.ProcessOperation line 83 file
f:\build\ims2014_knight\build_76.1\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
   - MgOpUpdateFeatures.Execute line 143 file
f:\build\ims2014_knight\build_76.1\ent\os\server\src\services\feature\OpUpdateFeatures.cpp
or
Invalid stream header exception.
It seems that the MgResourceIdentifier doesn't get constructed right or
something. I somehow got my VS2010 to stop here (not anymore)
         public override bool ResourceExists(string resourceid)
             //API is safe to call in MG 2.1 and newer
             var version = this.SiteVersion;
             if (version >= new Version(2, 1))
                 MgResourceService res =
this.Connection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
            **** var result = res.ResourceExists(new
MgResourceIdentifier(resourceid)); ****
                 LogMethodCall("MgResourceService::ResourceExists",
true, resourceid);
                 return result;
             else
                 return base.ResourceExists(resourceid);
Line 900+ at LocalNativeConnection.cs
Any hints how to get forward? I'm out of medicine..
Maybe I shold try that with MGE2011 (have it installed in our network)
- mika -
mika at digikartta.net kirjoitti 2013-12-03 16:38:
> It's possible. The project used to be MGE2011 project. There may be
> some MGE dlls in the projects bin folder, have to check if so. I have
> also a path to AIMS mapviewernet/bin denined into the environmental
> variables.
> - mika -
> Jackie Ng kirjoitti 2013-12-03 16:06:
>> You haven't mixed up your MG dlls with AIMS ones?
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/local-connection-tp5091886p5092403.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
