[mapguide-users] How to troubleshoot "The repository is already opened by another process"
Hans Milling
hm at geograf.dk
Wed Dec 18 04:47:34 PST 2013
Hi all
Using MapGuide 2.5 after a few hours with no problem the server suddently
states that the repository is in use. If I restart the service the problem
is gone. How can I troubleshoot what is going on?
Best regards
Hans Milling...
<2013-12-18T13:27:26> 7000 MapGuide Maestro API v4.0.1.6639 ::1
Administrator
Error: Cannot open repository:
D:\OSGeo\MapGuide25\Server\Repositories\Session\c0e0aaa0-67df-11e3-8000-00564406bffc_en_MTI3LjAuMC4x0B060B050B04.dbxml
The repository is already opened by another process (e.g. If you are
running the server interactively as an application from the command line,
are you also running the server as a service?).
StackTrace:
- MgSiteServiceHandler.ProcessOperation() line 83 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\site\SiteServiceHandler.cpp
- MgOpCreateSession.Execute() line 109 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\site\OpCreateSession.cpp
- MgServerSiteService.CreateSession() line 762 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\site\ServerSiteService.cpp
- MgServerResourceService.CreateRepository() line 541 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgSessionRepository.MgSessionRepository() line 76 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\resource\SessionRepository.cpp
- MgRepository.VerifyAccess() line 87 file
c:\working\build_area\mapguide\2.5.1\x64\mgdev\server\src\services\resource\Repository.cpp
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-troubleshoot-The-repository-is-already-opened-by-another-process-tp5094888.html
