[mapguide-users] Java memory leak
Zac Spitzer zac.spitzer at gmail.com
Sat Dec 21 05:41:24 PST 2013
"out of memory errors"
where are these showing up? can you please post extracts from the log files?
On Sat, Dec 21, 2013 at 2:33 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> You should check if your "memory leak" is not actually the resource demands
> of 150 users outpacing the resource cleanup of the JVM garbage collector.
> Try connecting jvisualvm.exe to the Tomcat instance and look at the memory
> usage graphs. Do you see consistent drops indicating the JVM garbage
> collector is at work? Or is it just a slowly rising plateau? The latter
> would indicate some kind of memory leak. The former would indicate more
> fine
> tuning of JVM options is required.
> - Jackie
> http://osgeo-org.1560.x6.nabble.com/Java-memory-leak-tp5095257p5095322.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20131221/7efae657/attachment.html>
