[mapguide-users] Problem using Filter on Layer
Jérôme DUCKERS
jerome.duckers at gmail.com
Fri Feb 1 01:17:41 PST 2013
Very strange, i've done the test with AutoCAD Map 3D
and with your filter, the contenido field is always different :S
2013/2/1 naish666 <naish666 at msn.com>
> When I do the Query with the same filter it shows me differents "contenido"
> and not the same "contenido" as in Maestro. I use a table in a
> PostgreSQL/PostGIS Database. I have export the table "restauracion" to a
> shp
> file and here you are:
> restauracion.zip
> <http://osgeo-org.1560.n6.nabble.com/file/n5031441/restauracion.zip>
> http://osgeo-org.1560.n6.nabble.com/Problem-using-Filter-on-Layer-tp5028966p5031441.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130201/ffddd05d/attachment.html>
