[mapguide-users] Mapguide Maestro - query filter in custom commands
Steve G
stevenlgolden at gmail.com
Tue Feb 5 09:11:22 PST 2013
Based on your screen capture, it looks like you are using the standard
"Search" function. The correct Query Filter would be:
DEPARTAMENTO LIKE '%$USER_VARIABLE%'
$USER_VARIABLE takes the input from the user to run the search. The % is a
wildcard. If you don't use it then your user will have to have an exact
match to the variable. You can play around if you only add it to the
beginning or end.
-Steve
View this message in context: http://osgeo-org.1560.n6.nabble.com/Mapguide-Maestro-query-filter-in-custom-commands-tp5032225p5032261.html
