[mapguide-users] Where is the Taskbar->Tools flyout stored plz??
Peter Shoemark
shoemark.peter at gmail.com
Wed Feb 6 00:28:36 PST 2013
Excellent thanks Jackie. I will take a look.
Cheers, Peter
On 06/02/2013, at 7:02 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> When you hit preview on a non-WebLayout resource, Maestro generates its own
> preview WebLayout that contains these 3 commands, when you're previewing a
> layout Maestro uses *that* layout for previewing.
> I guess you're wondering how these 3 commands are implemented?
> They are all invoke script commands, you can see the JS code here:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs#L130
> The strings assigned to the Script property of each command is the
> InvokeScript code
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Where-is-the-Taskbar-Tools-flyout-stored-plz-tp5032376p5032392.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
