[mapguide-users] FDO error with mapguide 2.4 on ubuntu 12.04
renardchan emailvalide at yahoo.fr
Sun Feb 10 16:30:45 PST 2013
Hi
I'm still working to run mapguide os on ubuntu 12.04. Now i have a problem
with FDO. During the install of mapguide 2.4, i check  RDBMS. But when i
want to add feature ressource, i have this error message . I verified
serverconfig.ini... fdo path was okay.
e remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Invalid Input Parameter (Cause: , Root Cause: Invalid Input Parameter)
and him details
System.Exception: The remote server returned an error: (559)
MgFdoException.:
 ---> System.Net.WebException: The remote server returned an error: (559)
MgFdoException.
  at System.Net.HttpWebRequest.CheckFinalStatus (System.Net.WebAsyncResult
result) [0x00000] in <filename unknown>:0
  at System.Net.HttpWebRequest.SetResponseData (System.Net.WebConnectionData
data) [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.OpenRead (System.String
req) [0x00000] in <filename unknown>:0
  at OSGeo.MapGuide.MaestroAPI.HttpServerConnection.get_FeatureProviders ()
  at Maestro.Base.Templates.FeatureSourceItemTemplate.CreateItem
(System.String startPoint, IServerConnection conn) [0x00000] in <filename
unknown>:0
  at Maestro.Base.Commands.NewItemCommand.Run () [0x00000] in <filename
unknown>:0
  at ICSharpCode.Core.WinForms.ToolBarCommand.OnClick (System.EventArgs e)
  at System.Windows.Forms.ToolStripItem.HandleClick (Int32 mouse_clicks,
System.EventArgs e) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStripItem.FireEvent (System.EventArgs e,
ToolStripItemEventType met) [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check)
System.Windows.Forms.ToolStripItem:FireEvent
(System.EventArgs,System.Windows.Forms.ToolStripItemEventType)
  at System.Windows.Forms.ToolStrip.OnMouseUp
(System.Windows.Forms.MouseEventArgs mea) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WmLButtonUp (System.Windows.Forms.Message&
m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m)
  at System.Windows.Forms.ScrollableControl.WndProc
(System.Windows.Forms.Message& m) [0x00000] in <filename unknown>:0
  at System.Windows.Forms.ToolStrip.WndProc (System.Windows.Forms.Message&
  at System.Windows.Forms.Control+ControlWindowTarget.OnMessage
  at System.Windows.Forms.Control+ControlNativeWindow.WndProc
  at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr
wParam, IntPtr lParam) [0x00000] in <filename unknown>:0
Thanks
Regards
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-error-with-mapguide-2-4-on-ubuntu-12-04-tp5033366.html
