[mapguide-users] Mapguide in linux
Jackie Ng jumpinjackie at gmail.com
Thu Feb 14 04:18:30 PST 2013
Data: Unless it's SQL Server or another Windows-only data source, your data
should be portable
Applications: If you're working with PHP or Java, they should be portable as
well. You may run into problems if you're using Windows-only APIs that have
been exposed through PHP or Java.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/Mapguide-in-linux-tp5034231p5034255.html
