[mapguide-users] Add layer dinamically from search results
yof85 loref85 at yahoo.com.ar
Tue Feb 19 11:03:52 PST 2013
So far I think this is the main part of buffer.aspx that I need to modify
MgFeatureQueryOptions query = new MgFeatureQueryOptions();
query.SetFilter(filter);
MgResourceIdentifier featureSource = new
MgResourceIdentifier(selLayer.GetFeatureSourceId());
MgFeatureReader features = featureSrvc.SelectFeatures(featureSource,
featureClassName, query);
if (features.ReadNext())
	MgClassDefinition classDef = features.GetClassDefinition();
	String geomPropName = classDef.GetDefaultGeometryPropertyName();
	do
		MgByteReader geomReader = features.GetGeometry(geomPropName);
		MgGeometry geom = agfRW.Read(geomReader);
		if (merge == 0)
			geomBuffer = geom.Buffer(dist, measure);
			if (geomBuffer != null)
				if (srsXform != null)
					geomBuffer = (MgGeometry)geomBuffer.Transform(srsXform);
				*AddFeatureToCollection(propCollection, agfRW, featId++, geomBuffer);*
				bufferFeatures++;
		else
				geom = (MgGeometry)geom.Transform(srsXform);
			inputGeometries.Add(geom);
	while (features.ReadNext());
	features.Close();
void *AddFeatureToCollection*(MgBatchPropertyCollection propCollection,
MgAgfReaderWriter agfRW, int featureId, MgGeometry featureGeom)
    MgPropertyCollection bufferProps = new MgPropertyCollection();
    MgInt32Property idProp = new MgInt32Property("ID", featureId);
    bufferProps.Add(idProp);
    MgByteReader geomReader = agfRW.Write(featureGeom);
    MgGeometryProperty geomProp = new MgGeometryProperty("GEOM",
geomReader);
    bufferProps.Add(geomProp);
    propCollection.Add(bufferProps);
If I'm close, I need to modify the AddFeatureToCollection to add the
selected points of my map, as I stated before, I want to create a new layer
from selected points and I need to keep the layer information in that new
layer
I tried to do something like this instead (based on this:
http://code.google.com/p/mapguide-contrib/source/browse/trunk/Libraries/DotNet/OSGeo.MapGuide.Extensions/OSGeo.MapGuide.Extensions/MgFeatureRepository.cs)
string[] propNames = features.GetPropertyNames();
	MgPropertyCollection res = features.ReadFeature(propNames);
	propCollection.Add(res);
features.Close();
But I get this error message: 'ReadFeature' doesn't exist in context.
How can I store the selected elements of the map in a
MgBatchPropertyCollection in order to create the new layer?
View this message in context: http://osgeo-org.1560.n6.nabble.com/Add-layer-dinamically-from-search-results-tp5033775p5035298.html
