[mapguide-users] authentication II
U. Schlachter mg at maw-gis.de
Mon Feb 25 06:11:53 PST 2013
Yes, I know that.
I now use a html-form to input the username and password.
then the only way I found was to pass these to fields as url parameters to
the main page:
"http://192.168.1.217/mapguide/fusion/templates/mapguide/maw/index.html?ApplicationDefinition=Library://Eckental/Layouts/MAWgis.ApplicationDefinition&locale=en&username=xxxx&password=yyyyy"
So everybody can the the password in browsers adressbar. Do you know an
other way to transmit the password ?
Martin Morrison wrote
> You are logged in as Anonymous.  You will simply get access denied to the
> protected object.
> You need to think outside MapGuide's box and handle your login there.  Put
> a login box in an iframe and then call MapGuide from there passing the
> login to the server to start the session.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA  24018
> 540.345.1410
> gis.edsi.com
> -----Original Message-----
> From:
> mapguide-users-bounces at .osgeo
>  [mailto:
> ] On Behalf Of U. Schlachter
> Sent: Saturday, February 23, 2013 8:44 AM
> To:
> mapguide-users at .osgeo
> Subject: Re: [mapguide-users] authentication II
> Hello,
> MGOS 2.4 , Win 2008, IIS 7
> I did all this steps above, but I still get no Login-Dialog.   The access
> is
> denied. Does anybody knows where I can search ?
> My errorlog :
> <2013-02-23T14:25:19> 	2224	MapGuide Developer	192.168.1.66	Anonymous
>  Error: Permission denied to resource:
> Library://Eckental/Layouts/test.ApplicationDefinition
>  StackTrace:
>   - MgResourceServiceHandler.ProcessOperation() line 80 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>   - MgOpGetResourceContent.Execute() line 120 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\OpGetResourceContent.cpp
>   - MgServerResourceService.GetResourceContent() line 1222 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ServerResourceService.cpp
>   - MgApplicationRepositoryManager.GetResourceContent() line 385 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
>   - MgResourceDefinitionManager.GetResource
> (MgLibraryResourceContents.dbxml)() line 320 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>   - MgResourceContentManager.GetDocument() line 590 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceContentManager.cpp
>   - MgResourceHeaderManager.CheckPermission() line 2558 file
> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceHeaderManager.cpp
> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5036353.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5036665.html
