[mapguide-users] authentication II
U. Schlachter mg at maw-gis.de
Thu Feb 28 23:41:59 PST 2013
Now I do it this way :
<frameset rows="60,*" frameborder="NO" border="0" framespacing="0">
    <frame src="Title.htm" name="TitleFrame" scrolling="NO" noresize>
    <frame src="<?php echo $url . $appdef . $auth ?>"
name="ViewerFrame">
</frameset>
Everthing is fine, but if the username or password wrong I only get the
background-image from fusion without any message. Where I can  link in to
produce a message ?
Martin Morrison wrote
> By using an iframe the login credentials don't show up in the address bar.
> Use https for further security.
> Martin Morrison
> Application Engineer
> Engineering Design Systems, Inc.
> 3780 Peters Creek Rd Ext SW
> Roanoke, VA  24018
> 540.345.1410
> gis.edsi.com
> -----Original Message-----
> From:
> mapguide-users-bounces at .osgeo
>  [mailto:
> ] On Behalf Of U. Schlachter
> Sent: Monday, February 25, 2013 9:12 AM
> To:
> mapguide-users at .osgeo
> Subject: Re: [mapguide-users] authentication II
> Yes, I know that.
> I now use a html-form to input the username and password.
> then the only way I found was to pass these to fields as url parameters to
> the main page:
> "http://192.168.1.217/mapguide/fusion/templates/mapguide/maw/index.html?ApplicationDefinition=Library://Eckental/Layouts/MAWgis.ApplicationDefinition&locale=en&username=xxxx&password=yyyyy"
> So everybody can the the password in browsers adressbar. Do you know an
> other way to transmit the password ?
>> You are logged in as Anonymous.  You will simply get access denied to
>> the protected object.
>> You need to think outside MapGuide's box and handle your login there.
>> Put a login box in an iframe and then call MapGuide from there passing
>> the login to the server to start the session.
>> Martin Morrison
>> Roanoke, VA  24018
>> 540.345.1410
>> gis.edsi.com
>> From:
>>  [mailto:
>> Sent: Saturday, February 23, 2013 8:44 AM
>> To:
>> Hello,
>> MGOS 2.4 , Win 2008, IIS 7
>> I did all this steps above, but I still get no Login-Dialog.   The access
>> is
>> denied. Does anybody knows where I can search ?
>> My errorlog :
>> <2013-02-23T14:25:19> 	2224	MapGuide Developer	192.168.1.66	Anonymous
>>  Error: Permission denied to resource:
>> Library://Eckental/Layouts/test.ApplicationDefinition
>>  StackTrace:
>>   - MgResourceServiceHandler.ProcessOperation() line 80 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
>>   - MgOpGetResourceContent.Execute() line 120 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\OpGetResourceContent.cpp
>>   - MgServerResourceService.GetResourceContent() line 1222 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ServerResourceService.cpp
>>   - MgApplicationRepositoryManager.GetResourceContent() line 385 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ApplicationRepositoryManager.cpp
>>   - MgResourceDefinitionManager.GetResource
>> (MgLibraryResourceContents.dbxml)() line 320 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
>>   - MgResourceContentManager.GetDocument() line 590 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceContentManager.cpp
>>   - MgResourceHeaderManager.CheckPermission() line 2558 file
>> c:\mg-2.4-x86\mgdev\server\src\services\resource\ResourceHeaderManager.cpp
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p503635
>> 3.html Sent from the MapGuide Users mailing list archive at
>> Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5036665.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> Martin Morrison
> Roanoke, VA  24018
> 540.345.1410
> gis.edsi.com
> From:
>  [mailto:
> To:
> Yes, I know that.
> the main page:
>> Martin Morrison
>> Roanoke, VA  24018
>> 540.345.1410
>> gis.edsi.com
>> From:
>>  [mailto:
>> To:
>> Hello,
>> is
>> My errorlog :
>>  StackTrace:
>> Nabble.com.
View this message in context: http://osgeo-org.1560.n6.nabble.com/authentication-II-tp5025338p5037677.html
