[mapguide-users] FDO Provider SQL Server Spatial and Table-Valued Functions
Gunter Becker gunter.becker at csogis.de
Mon Jan 21 06:34:00 PST 2013
Hi Jackie,
I have no need to abstract it behind a view cause I don't need these
function for MapGuide.
Like I said I'm using a feature in SQL Server that is called "Change Data
Capture". I have to use this for building a data history. When enabling this
feature on my tables with geometry column the Table-Valued Functions are
created automatically. I don't use it at the moment so it would be as easy
as to delete these function. This would work, yes!
But what if I need these function in the future?
I think the proper way would be that FDO/MapGuide recognize these functions
and pass by while gathering the required data! And therefore I would think
that this is a bug in the present!
Gunter
View this message in context: http://osgeo-org.1560.n6.nabble.com/FDO-Provider-SQL-Server-Spatial-and-Table-Valued-Functions-tp5028714p5028729.html
