[mapguide-users] Problem using Filter on Layer
Jérôme DUCKERS jerome.duckers at gmail.com
Tue Jan 22 05:53:16 PST 2013
Hello,
The tooltip is depending on your entire layer, not on a thema (filter).
Is the tooltip right when you remove your filter ?
duck.
2013/1/22 naish666 <naish666 at msn.com>
> Hello,
> I have a layer with bars, coffe shops, burger... On that layer I have a
> column called type (1, 2, 3...) where says if it is a bar, a burguer...
> When I put the filter type=1 OR tipe=2 and preview on map it only shows bar
> and burguer. The problem is that when I put the cursor over any of the
> points always show the same tooltipo whit the name of the same burger.
> What can I do?
> http://osgeo-org.1560.n6.nabble.com/Problem-using-Filter-on-Layer-tp5028966.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130122/90e09f8d/attachment.html>
