[mapguide-users] Studio ignoring specified coordinates
msteventon
msteventon at wtgroupllc.com
Tue Jan 22 17:11:17 PST 2013
Apparently this is a bug with AIMS2012/13. I got the following response from
Autodesk support:
/Thank you for contacting Autodesk Support.
After reviewing your case, I did some research, and found bug entry #1355930
"Failed to add multi CRSs for WFS Server". Apparently it was closed, as the
program's code was fixed. So if you are serving up WFS from AIMS 2013, you
should no longer experience the issue. The listed steps to reproduce are:
1. Select one feature resource and Enable WFS.
2. Add 2 CRSs (don't add EPSG 4326)
3. Publish.
4. send GetCapabilities request by mapagent.
Results:
Only 1 CRSs listed for the feature resource and CRS is 4326.
Expected results:
2 CRSs listed and default one is the one set in Step2.
Workaround:N
Does this sound like the issue that you are experiencing?
It's exactly my issue and it also happens in AIMS2013
View this message in context: http://osgeo-org.1560.n6.nabble.com/Studio-ignoring-specified-coordinates-tp5028775p5029129.html
