[mapguide-users] apache don't start on ubuntu 12.04
Jackie Ng jumpinjackie at gmail.com
Tue Jan 29 15:55:53 PST 2013
Is this a 64-bit Ubuntu? If so, you are treading in untested waters.
The 32-bit Ubuntu build of MapGuide *requires* a 32-bit Ubuntu. This is what
we produced the MapGuide binaries from and tested it on. If you are running
the 32-bit build in a 64-bit environment, at the very least you need x86
compiled versions of these libraries. You could try apt-get install
ia32-libs which *may* include the library in question, otherwise you're out
of luck.
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/apache-don-t-start-on-ubuntu-12-04-tp5030589p5030783.html
