[mapguide-users] SQL Server Spatial and SRS for geometry data type
Martin Morrison martin.morrison at edsi.com
Wed Jul 17 05:25:47 PDT 2013
Place a constraint on the db.
USE [YOUR_DB]
GO
ALTER TABLE [dbo].[parcels]  WITH CHECK ADD  CONSTRAINT [enforce_srid_geometry_parcels] CHECK  (([geom].[STSrid]=(2925)))
GO
ALTER TABLE [dbo].[parcels] CHECK CONSTRAINT [enforce_srid_geometry_parcels]
GO
I do not know whether or not this will still be read if the geom is null.  You should use your workaround and test that though.
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA  24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gunter Becker
Sent: Wednesday, July 17, 2013 6:12 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] SQL Server Spatial and SRS for geometry data type
I'm struggling with inserting geometries into SQL Server. After a coordinate system transformation all my geometries now have the appropriate SRS (SRID=25832). Before SRID was just 0.
Now when inserting new geometries via MapGuide/FDO into the tables I realized that sometimes they are written in the correct SRS (SRID=25832) and sometimes not (SRID=0). So I debugged the SQL that was send from MapGuide/FDO to the SQL Server and found out that the provider determine the SRID from the first row of the table where the geometry should be insert in:
SELECT TOP 1 [geom].STSrid as srid from [tablename]
BUT, when the first row has no geometry (geom=NULL) then this query returns NULL and the new geometry is written into the table with SRID=0 instead of the correct SRID=25832. (As a side note: that wouldn't have happen if there is a where-clause in this query like " WHERE geom IS NOT NULL")
MapGuide doesn't show up the new geometry since it has the wrong SRS.
Is there a way to insert the geometry with the correct SRS? Can I use fdo schema tables?
If yes, then which tables do I have to use to achieve my goal? Any other ideas?
Thanks, Gunter
View this message in context: http://osgeo-org.1560.x6.nabble.com/SQL-Server-Spatial-and-SRS-for-geometry-data-type-tp5067010.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
