[mapguide-users] Setting Maestro to move the application to a Web site
Steve G stevenlgolden at gmail.com
Mon Jun 3 12:17:39 PDT 2013
If I were to assume that you have MapGuide installed on your web server, have
the developer samples working properly, and have created your own
data/layers/map definitions...Are you asking about the actual file(s) that
you serve up through the browser to connect to the mapping service on your
web server (i.e. Mapguide)...Are you using the basic viewer (Ajax) or
Fusion?
*For Ajax:*
In the Developer's Guide, take a look at the Introduction and the Mapguide
Viewer sections with special attention to Hello, Map and Embedding a Viewer
on Your Own Page.  You can copy the code within those sections and replace
the WebLayout with your own.  If you are using PHP take a look at
www\phpviewersample\ajaxviewersample.php and/or phpsamples/main.php.
*For Fusion:*
Look at-
index.html and ApplicationDefinition.xml within
www\fusion\templates\mapguide\aqua [or any of the fusion template folders}
You can also see the "Public URL" in Maestro
-Steve G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setting-Maestro-to-move-the-application-to-a-Web-site-tp5057363p5057557.html
