[mapguide-users] WMS config files and image formats
Jackie Ng
jumpinjackie at gmail.com
Thu Jun 6 05:14:52 PDT 2013
Ok, here is the problem.
The configuration contains a bad mime type for the jpeg format. This is
what's causing MapGuide to throw that MgUnclassifiedException
It's image/jpg when it should be image/jpeg
And that's the solution, fix that bad mime type by editing the configuration
document's XML form and replace "image/jpg" with "image/jpeg", at least
until I fix the problem in Maestro proper.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-config-files-and-image-formats-tp5057179p5058397.html
