[mapguide-users] Partial Raster Transparency
Crispin_at_Linknode
crispin.hoult at linknode.co.uk
Mon Jun 10 04:20:39 PDT 2013
Has anyone worked on rasters with different levels of alpha transparency?
I am OK with bitonal/boolean images and setting a 'background' colour to
transparent. I have also played (unsucessfully) with adding an alpha into
an RGB foreground colour override.
What I would like to do is have an overlay (eg flood-plain type) that has a
100% transparency on one background and then be able to set a variable (like
70%) transparency on the remainder of the image so that other raster mapping
provides the background context. If I have an alpha setting in the original
image is that then preserved in processing for the map request?
Should I continue based on knowledge this approach will work or not?
It could be converted to a vector but would add a lot to processing source
data that I would rather avoid.
Many thanks,
Crispin
View this message in context: http://osgeo-org.1560.x6.nabble.com/Partial-Raster-Transparency-tp5059085.html
