[mapguide-users] Can’t save any changes in a map
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 11 23:20:06 PDT 2013
this is just running off old memories from years back....
I would suggest running fiddler (a http request monitor)
and looking for any problems which show up
sometimes there is a transparent proxy on your network
are you running IIS or Apache?
On Wed, Jun 12, 2013 at 4:01 PM, Emma Schmidt <emma.25 at gmx.net> wrote:
> Hi,
> we don't have a proxy server, but in case you are right, would it be
> possible to save layer changes?
> I can save layer changes but I can't save map changes, isn't that strange?
> This problem only occurs when I’m connected over the Network.
> If I ‘m connected over localhost everything works fine.
> So I don’t think it is because of the Roles.
> Thanks
>  *Gesendet:* Dienstag, 11. Juni 2013 um 10:32 Uhr
> *Von:* "Zac Spitzer" <zac.spitzer at gmail.com>
> *An:* "MapGuide Users Mail List" <mapguide-users at lists.osgeo.org>
> *Betreff:* Re: [mapguide-users] Can’t save any changes in a map
>  I bet you there is probably a proxy server involved :)
> On Tue, Jun 11, 2013 at 4:49 PM, Emma Schmidt <emma.25 at gmx.net> wrote:
>>   Hi,
>> I’ve got trouble with Maestro saving map changes.
>> Mapguide OS 2.4 (64bit)
>> Maestro 4.0.4
>> I can’t save any changes in a map, but I’am able to save an empty map.
>> I’m also able to save DataSources, Layers or Layouts.
>> Have you ever experience something like that?
>> Thanks for any reply
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> +61 405 847 168
Zac Spitzer
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130612/32c64b97/attachment.html>
