[mapguide-users] WFS Connection from OpenLayers
Rich Bauer rdbauer at gmail.com
Fri Jun 14 10:14:59 PDT 2013
Update...
I stumbled across something that creates the WFS connection from a WMS
Layer. I tried this earlier but evidently had the code wrong. Both layers
show up in the Layers panel as it is added to the map, but the WMS layer
shows up and the created WFS does not.  Code below:
var wmsParcels = new OpenLayers.Layer.WMS("Parcels",
http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Administrator&Password=admin
        { layers: 'Samples/Sheboygan/Layers/Parcels', transparent: true },
        { isBaseLayer: false, transitionEffect: 'resize', format:
'image/png' }
        //{ projection: new OpenLayers.Projection('EPSG:900913') }
map.addLayer(wmsParcels);
var wfsParcels = new OpenLayers.Layer.Vector("WFS Parcels", { protocol: new
OpenLayers.Protocol.WFS.fromWMSLayer(wmsParcels) });
map.addLayers([select, wfsParcels]);
With this there are no errors showing up in Chrome.
On Fri, Jun 14, 2013 at 7:37 AM, RDBauer <rdbauer at gmail.com> wrote:
> All,
> I have searched the list and Google and have not been able to find what I
> need. I am trying to connect to MapGuide (2.5 on test machine but 2.2 on
> production machine right now) from OpenLayers 2.12. I know that it would be
> easier to use Fusion, but it currently doesn't have the support for Mobile
> and that is what I need. Also, I can't use PHP or .NET for any code because
> it will be packaged in PhoneGap for a mobile app. Right now I am just
> trying
> to connect to the sample dataset to get things working and also, by actual
> data will most likely be served as the same WGS projection. My current code
> is:
> /map = new OpenLayers.Map({
>         div: "map",
>         theme: null,
>         projection: osmProj,
>         displayProjection: wgs,
>         maxExtent: extent,
>         scales: tempScales,
>         controls: [
>             new OpenLayers.Control.Attribution(),
>             new OpenLayers.Control.TouchNavigation({ dragPanOptions: {
> enableKinetic: true } }),
>             //new
> OpenLayers.Control.Scale(document.getElementById("mapScale"))
>         geolocate
>         //selectControl
> var layer = new OpenLayers.Layer.MapGuide("Sheboygan Tiled Layer", url,
> params, options);
>         strategies: [new OpenLayers.Strategy.Fixed()],
>         protocol: new OpenLayers.Protocol.WFS({
>             //version: "1.1.0",
>             srsName: "EPSG:4326",
>             url:
>             featureType: "ns34414117:ParcelsType",
>             featureNS: "http://www.opengis.net/gml",
>             geometryName: "SHPGEOM"
>         styleMap: new OpenLayers.StyleMap({
>             strokeWidth: 3,
>             strokeColor: "#333333"
>         //projection: wgs
> map.addLayer(layer);
> map.addLayer(wfsParcels);
> map.zoomToExtent(extent);/
> With this current code, I get the following error in Chrome Developer
> Tools:
> /Failed to load resource: Origin null is not allowed by
> Access-Control-Allow-Origin.
> XMLHttpRequest cannot load
> Origin null is not allowed by Access-Control-Allow-Origin. index.html:1/
> Things I am not sure about if they are correct are the "featureType" &
> "featureNS". I got those from the GETCAPABILITIES command. Any thoughts?
> Thanks,
> Rich
> http://osgeo-org.1560.x6.nabble.com/WFS-Connection-from-OpenLayers-tp5060185.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130614/eeac1b85/attachment.html>
