[mapguide-users] Setup Mapguide WebServer Extensions
Jackie Ng jumpinjackie at gmail.com
Tue Jun 18 21:04:57 PDT 2013
It's all in the webconfig.ini file of the Web Tier installation.
That tells you which MapGuide Server IP and port numbers to connect to. Edit
the webconfig.ini to point to the IP of the machine where the MapGuide
Server is installed and change the port numbers to match what the MapGuide
Server is listening on.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Setup-Mapguide-WebServer-Extensions-tp5060850p5060986.html
