[mapguide-users] WFS Connection from OpenLayers
Rich Bauer
rdbauer at gmail.com
Wed Jun 19 10:38:54 PDT 2013
I have gotten a little farther and am running into an error that I believe
might be MapGuide related. MgStreamIoException?
1. POST
http://localhost/mapguide/mapagent/mapagent.fcgi?USERNAME=Administrator&Password=admin559
(MgStreamIoException)
XMLHttpRequest.js:220<http://localhost/mapguide/RBAC%20Mobile%20GIS/lib/OpenLayers/Request/XMLHttpRequest.js>
1. fXMLHttpRequest_sendXMLHttpRequest.js:220<http://localhost/mapguide/RBAC%20Mobile%20GIS/lib/OpenLayers/Request/XMLHttpRequest.js>
2. cXMLHttpRequest.sendXMLHttpRequest.js:262<http://localhost/mapguide/RBAC%20Mobile%20GIS/lib/OpenLayers/Request/XMLHttpRequest.js>
3. (anonymous
function)Request.js:240<http://localhost/mapguide/RBAC%20Mobile%20GIS/lib/OpenLayers/Request.js>
1. XHR finished loading: "
". XMLHttpRequest.js:220<http://localhost/mapguide/RBAC%20Mobile%20GIS/lib/OpenLayers/Request/XMLHttpRequest.js>
3. (anonymous
The response preview is:
A stream IO exception occurred.A stream IO exception occurred.-
IsapiAgent.HttpExtensionProc() line 211 file IsapiAgent.cpp-
IsapiPostParser.Parse() line 196 file IsapiPostParser.cpp
I didn't see anything in the server logs through the Site Administrator
that stood out to me as being related to this. I can post code if it would
help.
Thanks,
Rich
On Fri, Jun 14, 2013 at 12:39 PM, Rich Bauer <rdbauer at gmail.com> wrote:
> FYI...I also posted in the OpenLayers list because I am not sure now if it
> is OpenLayers or MapGuide related.
> OpenLayers link:
> http://osgeo-org.1560.x6.nabble.com/Connecting-to-MapGuide-via-WFS-td5060238.html
> On Fri, Jun 14, 2013 at 12:14 PM, Rich Bauer <rdbauer at gmail.com> wrote:
>> Update...
>> I stumbled across something that creates the WFS connection from a WMS
>> Layer. I tried this earlier but evidently had the code wrong. Both layers
>> show up in the Layers panel as it is added to the map, but the WMS layer
>> shows up and the created WFS does not. Code below:
>> var wmsParcels = new OpenLayers.Layer.WMS("Parcels",
>> { layers: 'Samples/Sheboygan/Layers/Parcels', transparent: true },
>> { isBaseLayer: false, transitionEffect: 'resize', format:
>> 'image/png' }
>> //{ projection: new OpenLayers.Projection('EPSG:900913') }
>> map.addLayer(wmsParcels);
>> var wfsParcels = new OpenLayers.Layer.Vector("WFS Parcels", { protocol:
>> new OpenLayers.Protocol.WFS.fromWMSLayer(wmsParcels) });
>> map.addLayers([select, wfsParcels]);
>> With this there are no errors showing up in Chrome.
>> On Fri, Jun 14, 2013 at 7:37 AM, RDBauer <rdbauer at gmail.com> wrote:
>>> All,
>>> I have searched the list and Google and have not been able to find what I
>>> need. I am trying to connect to MapGuide (2.5 on test machine but 2.2 on
>>> production machine right now) from OpenLayers 2.12. I know that it would
>>> be
>>> easier to use Fusion, but it currently doesn't have the support for
>>> Mobile
>>> and that is what I need. Also, I can't use PHP or .NET for any code
>>> because
>>> it will be packaged in PhoneGap for a mobile app. Right now I am just
>>> trying
>>> to connect to the sample dataset to get things working and also, by
>>> actual
>>> data will most likely be served as the same WGS projection. My current
>>> code
>>> is:
>>> /map = new OpenLayers.Map({
>>> div: "map",
>>> theme: null,
>>> projection: osmProj,
>>> displayProjection: wgs,
>>> maxExtent: extent,
>>> scales: tempScales,
>>> controls: [
>>> new OpenLayers.Control.Attribution(),
>>> new OpenLayers.Control.TouchNavigation({ dragPanOptions: {
>>> enableKinetic: true } }),
>>> //new
>>> OpenLayers.Control.Scale(document.getElementById("mapScale"))
>>> geolocate
>>> //selectControl
>>> var layer = new OpenLayers.Layer.MapGuide("Sheboygan Tiled Layer", url,
>>> params, options);
>>> strategies: [new OpenLayers.Strategy.Fixed()],
>>> protocol: new OpenLayers.Protocol.WFS({
>>> //version: "1.1.0",
>>> srsName: "EPSG:4326",
>>> url:
>>> featureType: "ns34414117:ParcelsType",
>>> featureNS: "http://www.opengis.net/gml",
>>> geometryName: "SHPGEOM"
>>> styleMap: new OpenLayers.StyleMap({
>>> strokeWidth: 3,
>>> strokeColor: "#333333"
>>> //projection: wgs
>>> map.addLayer(layer);
>>> map.addLayer(wfsParcels);
>>> map.zoomToExtent(extent);/
>>> With this current code, I get the following error in Chrome Developer
>>> Tools:
>>> /Failed to load resource: Origin null is not allowed by
>>> Access-Control-Allow-Origin.
>>> XMLHttpRequest cannot load
>>> Origin null is not allowed by Access-Control-Allow-Origin. index.html:1/
>>> Things I am not sure about if they are correct are the "featureType" &
>>> "featureNS". I got those from the GETCAPABILITIES command. Any thoughts?
>>> Thanks,
>>> Rich
>>> View this message in context:
>>> http://osgeo-org.1560.x6.nabble.com/WFS-Connection-from-OpenLayers-tp5060185.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130619/80fee98e/attachment.html>
