[mapguide-users] Fusion Selection Handler
Greg
gbneff at cid.utah.gov
Tue Jun 25 14:17:11 PDT 2013
Mapguide 2.5 64 bit
Windows 7 64 bit
fusion viewer
I trying to write a simple selection handler and am struggling with the
Fusion.SelectionObject. In the following code I can capture the selection
and get the layers of the selected entities. I don't know why, however,
selection.getNumElements() always returns 0 regardless of the number
selected. The code is in my index.html file. Any ideas?
var fusionInitialized = function () {
$('AppContainer').resize({ forceResize: true });
mapWidget = Fusion.getMapById('Map');
mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, initPanelHandler);
mapWidget.registerForEvent(Fusion.Event.MAP_SELECTION_ON, selectionOn);
function selectionOn() {
maps = mapWidget.getAllMaps();
for (var i = 0; i < maps.length; i++) {
if (maps[i].arch == "MapGuide") {
maps[i].getSelection(displaySelection);
function displaySelection(selection) {
alert("Number selected is: " + selection.getNumElements()); //always
returns 0
alert("Number layers selected: " + selection.getNumLayers()); //returns
correct # of layers
if (selection && selection.getNumElements() == 1) {
var selLayer = selection.getLayer(0);
var selLayerName = selLayer.name();
alert("Layer = " + selLayerName);
View this message in context: http://osgeo-org.1560.x6.nabble.com/Fusion-Selection-Handler-tp5062180.html
