[mapguide-users] Remove Overview Map from Map Widget
Laura Kauria
lacation at gmail.com
Fri Jun 28 00:43:31 PDT 2013
Hi!
I got good instructions from Jackie to this question. This is for
aqua-template, but it works for others as well.
"It seems all the Fusion templates assume a Overview Map widget present even
if you don't use it.
For Aqua, if you just want to hide that window on a global template level
(the easiest solution), just comment out this line
http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/index.html#L47
in the index.html of the aqua template.
Hope that helps.
- Jackie"
BR, Laura
2013/6/28 Zac Spitzer <zac.spitzer at gmail.com>
> in fusion? just remove the overview widget from the applicationDefintion
> On Fri, Jun 28, 2013 at 10:08 AM, GordonL <
> gordon.luckett at arrowgeomatics.com> wrote:
>> Hi All,
>> MGOS 2.4 and 2.5.
>> I have a simple map that I use for an overview map.
>> I want to share 5 maps for people to choose using the MapMenu widget, but
>> want to omit the overview map.
>> Is this possible?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Remove-Overview-Map-from-Map-Widget-tp5062685.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> +61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20130628/83edcad8/attachment.html>
