[mapguide-users] WMS layer is not rendered in QuickPlot or in API Rendering Service
morkl
mapguide at morkl.se
Fri Jun 28 12:20:19 PDT 2013
I saw the same problem on a customer's installation just the other day. The
problem is that ArcGis WMS servers have default maximum width/height smaller
than a 300 DPI image covering a sheet paper.
I'm not sure if there is a workaround on the MapGuide side, but if you have
access to the ArcGis server, the setting can be changed there.
Relevant links:
http://forums.arcgis.com/threads/35645-ArcGIS-Server-WMS-Layer-Maximum-allowed-WIDTH
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Service_configuration_files/0093000000mr000000/
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMS-layer-is-not-rendered-in-QuickPlot-or-in-API-Rendering-Service-tp5062891p5062939.html
