[mapguide-users] Remove Overview Map from Map Widget
Jackie Ng jumpinjackie at gmail.com
Fri Jun 28 23:33:42 PDT 2013
The widget info button in the Fusion editor should tell you more information
about each extension property of that widget. If it doesn't then that's a
bug in that widget's widgetinfo.xml (ie. Those properties need to be
documented)
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Remove-Overview-Map-from-Map-Widget-tp5062685p5062990.html
