[mapguide-users] GeoPDF
Steve G
stevenlgolden at gmail.com
Wed Mar 13 14:55:57 PDT 2013
Thanks for the tips. In the more recent GDAL 1.9 releases, geospatial PDFs
seem to be a GDAL and OGR supported format:
http://www.gisinternals.com/sdk/PackageInfo.aspx?file=release-1600-gdal-mapserver.zip
However, I found some previous posts about the release of GDAL we used and
it seemed to point to this release:
http://www.gisinternals.com/sdk/PackageInfo.aspx?file=release-1600-gdal-1-9-0-mapserver-6-0-1.zip
which supports geospatial PDF for GDAL but not OGR.
Am I correct that inputs for GDAL (beyond a few specific formats) is
dependent on OGR supported formats. If so and if MGOS is using an older
release of GDAL, then I think you are right in that geospatial is not
supported. Is it possible to use a more recent release of GDAL that does
support geospatial PDF? How would I switch out the files?
Thanks,
Steve
View this message in context: http://osgeo-org.1560.n6.nabble.com/GeoPDF-tp5039978p5040226.html
