[mapguide-users] How to specify selText in Fusion's setSelection(selText, zoomTo)?
David Wilhelmsson david.wilhelmsson at 65nord.se
Fri Mar 15 01:41:35 PDT 2013
Fusion.Widget.Map's documentation includes the following:
-- start --
setSelection: function( selText,  zoomTo )
sets a Selection XML back to the server for each of the maps
Parameters
{String} selText the selection string
{Boolean} zoomTo if set, will zoom to the selection on completion
-- end --
How do I specify selText to be used in this function? I'm having trouble
trying to find any working examples for Fusion in MapGuide 2.4.
I have a layer on my map that includes data points with unique IDs and want
to be able to use setSelection to select and zoom to a selection for a given
ID.
Kind regards,
Dave.
View this message in context: http://osgeo-org.1560.n6.nabble.com/How-to-specify-selText-in-Fusion-s-setSelection-selText-zoomTo-tp5040544.html
