[mapguide-users] can't use mapguide os on ubuntu 12.04
renardchan
emailvalide at yahoo.fr
Thu Mar 21 06:25:37 PDT 2013
/so if you run it with mgserver.sh it works but with mgserverd.sh not?
yes it's this. With mgserverd.sh i can't connect to administrator page (or
do anything).
When i start apache and mapguide os in deamon i have this error message in
the error log
Apache log:
[Thu Mar 21 14:03:56 2013] [warn] No JkShmFile defined in httpd.conf. Using
default
/usr/local/mapguideopensource-2.4.0/webserverextensions/apache2/logs/jk-runtime-status
[Thu Mar 21 14:03:56 2013] [notice] Digest: generating secret for digest
authentication ...
[Thu Mar 21 14:03:56 2013] [notice] Digest: done
[Thu Mar 21 14:03:57 2013] [warn] No JkShmFile defined in httpd.conf. Using
default
[Thu Mar 21 14:03:57 2013] [notice] Apache/2.2.21 (Unix) DAV/2 PHP/5.3.8
mod_jk/1.2.30 configured -- resuming normal operations
[Thu Mar 21 14:04:07 2013] [error] [client 10.1.33.6] File does not exist:
/usr/local/mapguideopensource-2.4.0/webserverextensions/www/favicon.ico
This is my access.log. This lines are add when i try to connect to "MapGuide
Site Administrator".
I 'm trying to connect on a local network (i use a Pc to connect on a
server with this url http localhost://ip local
server/mapguide/mapadmin/login.php)
- [21/Mar/2013:14:11:32 +0100] "GET /mapguide/mapadmin/login.php HTTP/1.1"
200 3434
- [21/Mar/2013:14:11:32 +0100] "GET /favicon.ico HTTP/1.1" 404 209
- [21/Mar/2013:14:11:34 +0100] "POST /mapguide/mapadmin/login.php HTTP/1.1"
200 3514
- [21/Mar/2013:14:11:34 +0100] "GET /favicon.ico HTTP/1.1" 404 209
to finish, i have nothing in the mapguide errors,access,administrator logs.
Thanks,
Regards.
View this message in context: http://osgeo-org.1560.n6.nabble.com/can-t-use-mapguide-os-on-ubuntu-12-04-tp5041038p5042085.html
