[mapguide-users] Where is the file specified in ResourceId tag located?
Steve G stevenlgolden at gmail.com
Wed Mar 27 14:50:28 PDT 2013
Sounds like you are using the Fusion layouts.  The ResourceID tag should be
the Map feature that you have added to the layout.  If you haven't created a
map definition, then your layout will have no map to display.  If you are
using Maestro, you need to create a Map Definition, and then add this to
your fusion layout.  The Map Definition defines all of the layers in your
map, drawing order, initial map view, etc.  In Fusion you can add multiple
maps, therefore, it's possible to have multiple ResourceID tags in the xml
that relate to each of these Maps.  The ResourceID for map features should
reference something like
Library://foldername/foldername/mymap.MapDefinition.  The map definitions
are internally stored within the mapguide repository structure so you will
not actually find them as separate files.
Steve G
View this message in context: http://osgeo-org.1560.n6.nabble.com/Where-is-the-file-specified-in-ResourceId-tag-located-tp5043385p5043406.html
