[mapguide-users] Kaliopa MobileViewer Format Parameter
Srecko Lipovsek srecko.lipovsek at kaliopa.si
Mon May 6 00:12:08 PDT 2013
Hi Rémy,
You can change format in Default.debug.js in line 520.
After changing this javascript file just run 00_minify.bat to create
minified default.min.js, which is used in default.aspx ...
Srečko Lipovšek
View this message in context: http://osgeo-org.1560.x6.nabble.com/Kaliopa-MobileViewer-Format-Parameter-tp5051432p5051493.html
