[mapguide-users] Upgrading to MGOS 2.5 from 2.2
cremebrulee iowa747 at gmail.com
Mon May 13 15:42:23 PDT 2013
I am going through the build process of the MGOS 2.5 source code on RHEL 5.
(Note, had to use dos2unix command for most of the scripts before they could
execute).
I run into the following build error and was wondering if anyone knows
why.....
It is for the dbxml script : "buildall.sh" in (MGOS source code /Oem/dbxml
and t*he error is in line 346 during the make* command. Here's the output
just before the error get's generated (I have also included the script)
buildall.sh <http://osgeo-org.1560.x6.nabble.com/file/n5053002/buildall.sh>
Building Berkeley DB
./libtool --mode=compile gcc -c -I. -I../dist/..  -D_GNU_SOURCE -D_REENTRANT
-O3  ../dist/../mutex/mut_tas.c
libtool: compile:  gcc -c -I. -I../dist/.. -D_GNU_SOURCE -D_REENTRANT -O3
../dist/../mutex/mut_tas.c  -fPIC -DPIC -o .libs/mut_tas.o
../dist/../mutex/mut_tas.c: In function ‘__db_tas_mutex_init’:
../dist/../mutex/mut_tas.c:39: warning: assignment makes pointer from
integer without a cast
../dist/../mutex/mut_tas.c:44: error: ‘EINVAL’ undeclared (first use in this
function)
../dist/../mutex/mut_tas.c:44: error: (Each undeclared identifier is
reported only once
../dist/../mutex/mut_tas.c:44: error: for each function it appears in.)
../dist/../mutex/mut_tas.c:52: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c: In function ‘__db_tas_mutex_lock_int’:
../dist/../mutex/mut_tas.c:78: error: ‘DB_MUTEXREGION’ undeclared (first use
in this function)
../dist/../mutex/mut_tas.c:78: error: ‘mtxregion’ undeclared (first use in
this function)
../dist/../mutex/mut_tas.c:92: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c:93: warning: assignment makes pointer from
../dist/../mutex/mut_tas.c:111: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c:143: error: dereferencing pointer to incomplete
type
type
../dist/../mutex/mut_tas.c:155: error: ‘MUTEX_PAUSE’ undeclared (first use
in this function)
../dist/../mutex/mut_tas.c:156: error: expected ‘;’ before ‘continue’
../dist/../mutex/mut_tas.c:192: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c:193: error: dereferencing pointer to incomplete
type
type
../dist/../mutex/mut_tas.c: In function ‘__db_tas_mutex_unlock’:
../dist/../mutex/mut_tas.c:460: warning: assignment makes pointer from
../dist/../mutex/mut_tas.c:501: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c:502: error: dereferencing pointer to incomplete
type
../dist/../mutex/mut_tas.c: In function ‘__db_tas_mutex_destroy’:
../dist/../mutex/mut_tas.c:549: warning: assignment makes pointer from
../dist/../mutex/mut_tas.c:551: error: dereferencing pointer to incomplete
type
make: *** [mut_tas.lo] Error 1
BDBXML: Error build failed (2).................
-MGnoob
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upgrading-to-MGOS-2-5-from-2-2-tp5049931p5053002.html
