[mapguide-users] Parent groups missing from RuntimeMap
Hans Milling hm at geograf.dk
Fri May 17 00:16:38 PDT 2013
Using MapGuide OS 2.2 and Maestro API 4.0.4, I have a problem when creating a
runtime map.
The map has a group childcare and a sub group schools with some layers
(public, private etc). When I use the CreateRuntimeMap all the groups are
created with no parent groups (the RuntimeMapLayer.Group is always an empty
string). When I look in the MapDefinition BaseMap the groups are there and
with their parent groups.
The source looks like this:
      IServerConnection con =
ConnectionProviderRegistry.CreateConnection("Maestro.Http", ...);
      IMapDefinition mdef =
(IMapDefinition)con.ResourceService.GetResource("library://maps/testmap.MapDefinition");
      IMappingService mSvc =
(IMappingService)con.GetService((int)ServiceType.Mapping);
      RuntimeMap rtm = mSvc.CreateMap(mdef);
The rtm.Groups only contains the groups that has layers and none of them has
any parent groups.
If I preview the map from Maestro the legend is correct with nested groups.
Is there another way to load the runtime map getting the correct group
structure?
I looked at the Maestro source and the RuntimeMapGroup.cs constructors do
not save the parent group from the IMapLayerGroup property into the new
RintimeMapGroup. Is there a reason for this? Also why does it work in
preview in Maestro, is there another way to load the runtime map where the
groups are correct?
Best regards
  Hans Milling...
View this message in context: http://osgeo-org.1560.x6.nabble.com/Parent-groups-missing-from-RuntimeMap-tp5053876.html
